        We use the general term event for any
            type of occurrence on a switch that could generate a log message or require an
            action.
    For example, a link going down, a user logging in, a command entered on
            the command line, or the software executing a debugging statement, are all events that
            might generate a log message. The system for saving, displaying, and filtering events is
            called the EMS. With EMS, you have many options about which events generate log
            messages, where the messages are sent, and how they are displayed.
    Using EMS you can:
            - Send event messages to a number of logging targets (for example,
                syslog host and NVRAM).
            - Filter events per target, by:
                - Component, subcomponent, or specific condition (for example,
                            BGP messages,
                            IGMP. Snooping messages, or
                        the IP.Forwarding.SlowPathDrop condition).
                - Match expression (for example, any messages containing the
                        string “user 5”).
                - Matching parameters (for example, only messages with source
                        IP addresses in the 10.1.2.0/24 subnet).
                - Severity level (for example, only messages of severity
                        critical, error, or warning).
            - Change the format of event messages (for example, display the
                date as “12-May-2005” or “2005-05-12”).
            - Display log messages in real time and filter the messages that
                are displayed, both on the console and from Telnet sessions.
            - Display stored log messages from the memory buffer or
                NVRAM.
            - Upload event logs stored in memory buffer or NVRAM to a TFTP
                server.
            - Display counts of event occurrences, even those not included in
                filter.
            - Display debug information using a consistent configuration
                method.
    EMS supports IPv6 as a parameter for filtering events.
